Ir para o conteúdo principal
Toshiba Encore WT8-A Battery Replacement
O que você precisa
  1. Toshiba Encore WT8-A Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
  2. Toshiba Encore WT8-A Battery Replacement: passo 2, imagem 1 %32 Toshiba Encore WT8-A Battery Replacement: passo 2, imagem 2 %32
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
  3. Toshiba Encore WT8-A Battery Replacement: passo 3, imagem 1 %32 Toshiba Encore WT8-A Battery Replacement: passo 3, imagem 2 %32
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
  4. Toshiba Encore WT8-A Battery Replacement: passo 4, imagem 1 %32 Toshiba Encore WT8-A Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
  5. Toshiba Encore WT8-A Battery Replacement: passo 5, imagem 1 %32
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  6. Toshiba Encore WT8-A Battery Replacement: passo 6, imagem 1 %32
    • Battery will lift out of the device.
Conclusão
Equipe
USF Tampa, Team 17-4, Blackwell Fall 2016 Membro de USF Tampa, Team 17-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G4
Membros da 3
Autoria de 8 guias
3 comentários
Hi can I get Battery for Toshiba Encore 2 WT8-B?
Thanks
Regards
Dr Ravindra
Ravindra MIstry - Responder
Hi friends can I get Battery for Toshiba Encore 2 WT8-B
Thanks
Regards
Dr Ravindra
who can I replacement socket charging for toshiba tablet WT8-A
monzer daoud - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 5,077
