Ir para o conteúdo principal
Toshiba Encore Mini Speakers Replacement
O que você precisa
  1. Toshiba Encore Mini Speakers Replacement, Battery: passo 1, imagem 1 %32 Toshiba Encore Mini Speakers Replacement, Battery: passo 1, imagem 2 %32
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: passo 2, imagem 1 %32
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: passo 3, imagem 1 %32
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: passo 4, imagem 1 %32 Toshiba Encore Mini Speakers Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: passo 6, imagem 1 %32
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: passo 7, imagem 1 %32
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Conclusão
Khaled Alsaghayer
Membro desde: 03/04/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G5, Wilson Spring 2017 Membro de IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 168
