Ir para o conteúdo principal
Toshiba Encore Mini Battery Replacement
O que você precisa
  1. Toshiba Encore Mini Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Encore Mini Battery Replacement, Battery: passo 1, imagem 2 %32
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: passo 2, imagem 1 %32
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: passo 3, imagem 1 %32
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: passo 4, imagem 1 %32 Toshiba Encore Mini Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
Conclusão
5 outras pessoas executaram este guia.
Equipe
UW Tacoma, Team 1-3, Liner SU 2015 Membro de UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Membros
Autoria de 6 guias
2 comentários
Be sure to remove any SD cards you have first.
ecw0647 - Responder
But where do i buy the battery?
sissyhana - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 4,138
