Ir para o conteúdo principal
Toshiba Encore 2 WT10-A Motherboard Replacement
O que você precisa
  1. Toshiba Encore 2 WT10-A Motherboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Encore 2 WT10-A Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 2, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 2, imagem 2 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 3, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 3, imagem 2 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 3, imagem 3 %32
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 4, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 4, imagem 2 %32
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 5, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 5, imagem 2 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 5, imagem 3 %32
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 6, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the battery from the compartment.
  7. Toshiba Encore 2 WT10-A Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Once you take off the back case and battery, set tablet screen faced down.
    • Unscrew the 11 screws shown in the markups with a Phillips #00 screwdriver.
    • BE AWARE: Screws are extremely small.
  8. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 8, imagem 2 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Before taking off motherboard, grab tweezers to peel off tape on the two ribbons marked on the picture.
    • Once tape is removed, use the same tweezers to carefully pull the ribbons downwards to disconnect from motherboard.
  9. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 9, imagem 1 %32
    • On the top left corner, pull the black compartment carefully upwards.
    • This component still has wires attached, so be careful not to sever the wires as you remove it.
  10. Toshiba Encore 2 WT10-A Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Encore 2 WT10-A Motherboard Replacement: passo 10, imagem 2 %32
    • Once black compartment is off, you will be prepared to disconnect motherboard.
    • Carefully lift motherboard upwards with the black compartment.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 665
