Ir para o conteúdo principal
Toshiba Encore 2 WT10-A Battery Replacement
O que você precisa
  1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, imagem 2 %32 Toshiba Encore 2 WT10-A Battery Replacement, Battery: passo 1, imagem 3 %32
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Battery Replacement: passo 2, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 2, imagem 2 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Battery Replacement: passo 3, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 3, imagem 2 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 3, imagem 3 %32
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Battery Replacement: passo 4, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 4, imagem 2 %32
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Battery Replacement: passo 5, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 5, imagem 2 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 5, imagem 3 %32
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Battery Replacement: passo 6, imagem 1 %32 Toshiba Encore 2 WT10-A Battery Replacement: passo 6, imagem 2 %32
    • Remove the battery from the compartment.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 1,830
