Ir para o conteúdo principal
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: passo 1, imagem 1 %32
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: passo 2, imagem 1 %32 Toshiba Dynabook T552-58G Space Bar Replacement: passo 2, imagem 2 %32
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: passo 3, imagem 1 %32
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, imagem 1 %32 Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, imagem 2 %32 Toshiba Dynabook T552-58G Space Bar Replacement: passo 4, imagem 3 %32
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 22
Duração total: 626
