Ir para o conteúdo principal
Toshiba Dynabook T552-58G Hard Drive Replacement
O que você precisa
  1. Toshiba Dynabook T552-58G Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 3, imagem 2 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 5, imagem 2 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 6, imagem 2 %32 Toshiba Dynabook T552-58G Hard Drive Replacement: passo 6, imagem 3 %32
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • The hard drive is located in the under the L-shaped panel on the back of the computer.
  8. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 8, imagem 1 %32
    • Carefully push the hard drive to the left
  9. Toshiba Dynabook T552-58G Hard Drive Replacement: passo 9, imagem 1 %32
    • Gently lift the hard drive using your fingers.
Conclusão
Um comentário
Está em inglês deveria ter como traduzir aqui dentro da plataforma
Standley Richande - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 749
