Ir para o conteúdo principal
Toshiba Dynabook T552-58G Battery Replacement
  1. Toshiba Dynabook T552-58G Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the computer so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Battery Replacement: passo 2, imagem 1 %32 Toshiba Dynabook T552-58G Battery Replacement: passo 2, imagem 2 %32
    • Push the right battery cover lock (labeled as number 1) to the right.
    • It should now be on the unlock symbol.
  3. Toshiba Dynabook T552-58G Battery Replacement: passo 3, imagem 1 %32
    • Push and hold the left battery cover lock (labeled as number 2) to the left.
    • It should now be on the number 2.
  4. Toshiba Dynabook T552-58G Battery Replacement: passo 4, imagem 1 %32 Toshiba Dynabook T552-58G Battery Replacement: passo 4, imagem 2 %32
    • While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
    • Lift up on the battery pack to remove it from computer.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Note to the needed.... International Lakes.
Multi User - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 878
