Ir para o conteúdo principal
Toshiba Dynabook AX 53D Memory Replacement
O que você precisa
  1. Toshiba Dynabook AX 53D Memory Replacement, Battery: passo 1, imagem 1 %32
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Memory Replacement: passo 2, imagem 1 %32
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Memory Replacement, Memory: passo 3, imagem 1 %32
    • Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
  4. Toshiba Dynabook AX 53D Memory Replacement: passo 4, imagem 1 %32
    • Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
  5. Toshiba Dynabook AX 53D Memory Replacement: passo 5, imagem 1 %32
    • Gently pull the chip out of the clips.
    • Touching the contacts or the chips on the board could destroy the components.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher
Membro desde: 03/20/17
525 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 379
