Ir para o conteúdo principal
Toshiba Dynabook AX 53D Keyboard Replacement
O que você precisa
  1. Toshiba Dynabook AX 53D Keyboard  Replacement, Battery: passo 1, imagem 1 %32
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Keyboard  Replacement: passo 2, imagem 1 %32
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Keyboard  Replacement, Keyboard: passo 3, imagem 1 %32
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Keyboard  Replacement: passo 4, imagem 1 %32 Toshiba Dynabook AX 53D Keyboard  Replacement: passo 4, imagem 2 %32
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Keyboard  Replacement: passo 5, imagem 1 %32
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Keyboard  Replacement: passo 6, imagem 1 %32 Toshiba Dynabook AX 53D Keyboard  Replacement: passo 6, imagem 2 %32
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
Conclusão
Christopher
Membro desde: 03/20/17
525 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,215
