Ir para o conteúdo principal
Toshiba Chromebook CB35-A3120 Speakers Replacement
O que você precisa
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: passo 1, imagem 1 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: passo 1, imagem 2 %32
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 2, imagem 1 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, imagem 1 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, imagem 2 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 3, imagem 3 %32
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, imagem 1 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, imagem 2 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 4, imagem 3 %32
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 5, imagem 1 %32 Toshiba Chromebook CB35-A3120 Speakers Replacement: passo 5, imagem 2 %32
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
Conclusão
Jayce Houghton
Membro desde: 02/15/17
176 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-6, Remmell Spring 2017 Membro de USF Tampa, Team 15-6, Remmell Spring 2017
USFT-REMMELL-S17S15G6
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 734
