Ir para o conteúdo principal
Toshiba Chromebook 2 Touchpad Replacement
O que você precisa
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Touchpad Replacement: passo 2, imagem 1 %32
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Touchpad Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 3, imagem 2 %32
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Touchpad Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 4, imagem 2 %32
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Touchpad Replacement: passo 5, imagem 1 %32
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: passo 6, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement, Battery: passo 6, imagem 2 %32
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Touchpad Replacement: passo 7, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 7, imagem 2 %32
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Touchpad Replacement: passo 8, imagem 1 %32
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: passo 9, imagem 1 %32
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 2 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 10, imagem 3 %32
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Touchpad Replacement: passo 11, imagem 1 %32
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: passo 12, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: passo 12, imagem 2 %32
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
  13. Toshiba Chromebook 2 Touchpad Replacement: passo 13, imagem 1 %32
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
  14. Toshiba Chromebook 2 Touchpad Replacement: passo 14, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 14, imagem 2 %32
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
  15. Toshiba Chromebook 2 Touchpad Replacement: passo 15, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 15, imagem 2 %32
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
  16. Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 2 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 16, imagem 3 %32
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
  17. Toshiba Chromebook 2 Touchpad Replacement: passo 17, imagem 1 %32 Toshiba Chromebook 2 Touchpad Replacement: passo 17, imagem 2 %32
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
Conclusão
4 outras pessoas executaram este guia.
Haley Hattendorf
Membro desde: 10/06/16
598 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-4, Livingston Fall 2016 Membro de Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Membros
Autoria de 11 guias
2 comentários
Thanks for this guide! Worked perfectly.
Mathias Maes - Responder
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 1,872
