Ir para o conteúdo principal
Toshiba Chromebook 2 Speakers Replacement
O que você precisa
  1. Toshiba Chromebook 2 Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Speakers Replacement: passo 2, imagem 1 %32
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Speakers Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 Speakers Replacement: passo 3, imagem 2 %32
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Speakers Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 Speakers Replacement: passo 4, imagem 2 %32
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Speakers Replacement: passo 5, imagem 1 %32
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Speakers Replacement, Battery: passo 6, imagem 1 %32 Toshiba Chromebook 2 Speakers Replacement, Battery: passo 6, imagem 2 %32
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Speakers Replacement: passo 7, imagem 1 %32 Toshiba Chromebook 2 Speakers Replacement: passo 7, imagem 2 %32
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Speakers Replacement: passo 8, imagem 1 %32
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Speakers Replacement, Speakers: passo 9, imagem 1 %32
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Speakers Replacement: passo 10, imagem 1 %32 Toshiba Chromebook 2 Speakers Replacement: passo 10, imagem 2 %32 Toshiba Chromebook 2 Speakers Replacement: passo 10, imagem 3 %32
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Speakers Replacement: passo 11, imagem 1 %32
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
Conclusão
4 outras pessoas executaram este guia.
Alec Marnoch
Membro desde: 10/06/16
257 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-4, Livingston Fall 2016 Membro de Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 795
