Ir para o conteúdo principal
Toshiba Chromebook 2 LCD Screen Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Chromebook 2 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Toshiba Chromebook 2 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Toshiba Chromebook 2 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Remove the two screws which are located at the bottom corners of the screen.
    • The screws are underneath little covers which can be removed with a craft knife.
  2. Toshiba Chromebook 2 LCD Screen Replacement: passo 2, imagem 1 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 2, imagem 2 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 2, imagem 3 %32
    • Carefully slide your plastic spudger tool into the crack between the outer edge of the bezel and the back of the display assembly.
    • Slide it all the way along all edges, carefully unclipping the bezel from the back assembly.
    • Be very careful and take your time - it's easy to snap the bezel or to break the clips, making reassembly less secure.
    • Once everything is released you should be able to lift up the bezel and it freely come away.
  3. Toshiba Chromebook 2 LCD Screen Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 3, imagem 2 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 3, imagem 3 %32
    • Remove the two screws holding the back assembly to the hinge mechanism.
    • Be careful as you're unscrewing these! Support the display assembly with your other hand.
    • Lay the loose display assembly down and then fold the metal foil tabs up and out of the way.
    • Some models' screens are held down by adhesive; if this is the case with yours, carefully pry the screen away from the back being careful not to damage any cables.
    • If your display is screwed down, there will be extra screws to remove and it should then come away freely.
  4. Toshiba Chromebook 2 LCD Screen Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 4, imagem 2 %32 Toshiba Chromebook 2 LCD Screen Replacement: passo 4, imagem 3 %32
    • Fold the loose screen down onto the laptop's keyboard, as if you were closing the laptop, with the rear of the display assembly still open.
    • Carefully remove the connecting ribbon cable as shown in the picture.
    • You may need to remove the sticky adhesive tape which holds the connector in place before you can remove it.
    • When reassembling, replace this with some fresh sticky table to help prevent it coming loose over time.
Conclusão
Paul Freeman-Powell
Membro desde: 08/07/17
109 Reputação
Autoria de 1 guia
3 comentários
Thanks for this guide!
After seeing how easy this little project would be I immediately ordered a new screen.
Ishtar Bruintjues - Responder
Canyou tell me where you did buy the new screen & the price
Kind regards
Peter
Pete -
Dear Sir
I have replace my Chromebook LCD panel same to same your as shown on pictures but when i closed all fitting of LCD panel then i start but laptop goes to on but display is not coming . No back light no data LCD panel . I have check the LCD panel first before fitting I have checked complete any braked jack or cables or LCD panel but everything is see to clear . Can you help me .
Thanks
Waseem Hassan
Waseem.eng@hotmail.com
Lahore Pakistan
Waseem Hassan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,357
