Ir para o conteúdo principal
Toshiba Chromebook 2 Battery Replacement
O que você precisa
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: passo 2, imagem 1 %32
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: passo 3, imagem 1 %32 Toshiba Chromebook 2 Battery Replacement: passo 3, imagem 2 %32
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: passo 4, imagem 1 %32 Toshiba Chromebook 2 Battery Replacement: passo 4, imagem 2 %32
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: passo 5, imagem 1 %32
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: passo 6, imagem 1 %32 Toshiba Chromebook 2 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: passo 7, imagem 1 %32 Toshiba Chromebook 2 Battery Replacement: passo 7, imagem 2 %32
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: passo 8, imagem 1 %32
    • Remove the battery by gently pulling up on the bottom corners.
    Thank you for the step by step guide!
    yoena lopez - Responder
Conclusão
50 outras pessoas executaram este guia.
Foster Chaney
Membro desde: 10/08/15
762 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Hagerty Fall 2015 Membro de IUPUI, Team 1-3, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G3
Membros da 5
Autoria de 7 guias
7 comentários
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - Responder
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - Responder
Good instructions, my chrome is back to normal again .
Alexander Slaven - Responder
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - Responder
Thank you, easy to follow, works like a dream
steve smith - Responder
No cursor here either. Did Chris in UK get an answer?
laurasan464 - Responder
Great set of instructions. Somewhere over the last 8 years I lost two screws out of the bottom, but it all worked fine regardless.
Excited to see battery life return to normal.
Phillip Mills - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 32
Duração total: 28,744
