Ir para o conteúdo principal
Toshiba Canvio Connect V73600-C Disassembly
O que você precisa
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: passo 1, imagem 1 %32 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: passo 1, imagem 2 %32
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: passo 2, imagem 1 %32
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: passo 3, imagem 1 %32
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: passo 4, imagem 1 %32
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: passo 5, imagem 1 %32
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, imagem 1 %32 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, imagem 2 %32 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: passo 6, imagem 3 %32
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Conclusão
CONVERSION
Membro desde: 03/07/20
1.282 Reputação
Autoria de 8 guias
Equipe
Australia Membro de Australia
Community
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 134
Duração total: 5,118
