Ir para o conteúdo principal
Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement
O que você precisa
  1. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Back Cover: passo 1, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 2, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 2, imagem 2 %32
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 3, imagem 1 %32
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 4, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 4, imagem 2 %32
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Battery: passo 5, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Battery: passo 5, imagem 2 %32
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 6, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 6, imagem 2 %32
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 7, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 7, imagem 2 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 7, imagem 3 %32
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 8, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 8, imagem 2 %32
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Fan: passo 9, imagem 1 %32
    • Locate the fan
  10. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 10, imagem 1 %32
    • Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • These screws only loosen partially, they do not disconnect.
  11. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 11, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 11, imagem 2 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 11, imagem 3 %32
    • The top wire is the fan's wire. Remove it by pulling it from the motherboard.
  12. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 12, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 12, imagem 2 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 12, imagem 3 %32
    • To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
    • After the flap is lifted, pull the wire up out of the connector socket.
  13. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 13, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 13, imagem 2 %32
    • Remove the headphone jack wire by pulling it out of the connector socket.
  14. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 14, imagem 1 %32
    • Remove the Phillip 3.6 mm screw from the fan using a Phillips #1 screwdriver.
  15. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 15, imagem 1 %32
    • Lift up on the metal plate that hold the screws to start removing the fan.
  16. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 16, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 16, imagem 2 %32 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 16, imagem 3 %32
    • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
    • These wires require you to gently pull them out of there tunnel.
    • Once the wires are removed the fan should be removed entirely.
  17. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, WiFi PCB: passo 17, imagem 1 %32
    • The WiFi PCB is located next to the fan.
  18. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 18, imagem 1 %32
    • Remove the Phillips 3.7 mm screw using a Phillips #1 screwdriver.
  19. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: passo 19, imagem 1 %32
    • Gently remove the WiFi PCB by pulling upward.
Conclusão
Jillian Thomas
Membro desde: 10/14/17
209 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G121, Cagle Fall 2017 Membro de USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
Membros da 3
Autoria de 14 guias
Um comentário
The article has some mistakes, namely, this isn’t the WiFi / WLAN, it is a USB port and card reader slot PCB. I came to iFixIt to double-check the part to upgrade to WiFi 6 (ax). Once you fix the part name, the article is good! The part number DA0BUITH8D0 is what to search for when trying to buy one. I didn’t need one, but looked it up just the same, there are not a ton of these out there and I would probably just resort to a USB reader.
Vic Lovan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 350
