Ir para o conteúdo principal
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
O que você precisa
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: passo 1, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 2, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 2, imagem 2 %32
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 3, imagem 1 %32
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 4, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 4, imagem 2 %32
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: passo 5, imagem 1 %32
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: passo 6, imagem 1 %32
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 410
