Ir para o conteúdo principal
Toshiba CB35-C3300 Chromebook 2 Battery Replacement
O que você precisa
  1. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: passo 1, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 2, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 2, imagem 2 %32
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 3, imagem 1 %32
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 4, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 4, imagem 2 %32
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: passo 5, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: passo 5, imagem 2 %32
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 6, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 6, imagem 2 %32
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 7, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 7, imagem 2 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 7, imagem 3 %32
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 8, imagem 1 %32 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: passo 8, imagem 2 %32
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
Conclusão
Uma outra pessoa concluiu este guia.
varun kapadia
Membro desde: 10/18/17
219 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G121, Cagle Fall 2017 Membro de USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
Membros da 3
Autoria de 14 guias
Um comentário
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
Guy Rogers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,215
