Introdução
Removing the back may be the easiest thing to do, however do not forget about the screws hidden under the rubber foot pads!
Peças
Não são necessárias peças.
  1. Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool. Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
    • Remove the 2 rubber foot pads from the bottom with the small Plastic Opening tool.
  2. Remove the 10 7.1 mm screws using Phillips #1 screwdriver. Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Loosen the back cover by using a plastic opening tool all the way around the device.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
  5. Remove the back cover by gently lifting up on one side of the device. The easiest side to lift up on is the one with the removed rubber foot pads.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
Conclusão
Uma outra pessoa concluiu este guia.
Jillian Thomas
165 reputação
4 Guides authored
Equipe
USF Tampa, Team S1-G121, Cagle Fall 2017 Membro de USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Membros
6 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Todo: 95
