Peças
Não são necessárias peças.
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
    • Use your fingers to gently detach the ribbon wire from the logic board.
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
    • Use your thumb to peel the keypad from the device.
Conclusão
Christopher
90 reputação
8 Guides authored
Equipe
Cal Poly, Team 16-6, Maness Spring 2010 Membro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Membros
16 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 2,505
