Introdução
Use this guide to replace your Toshiba AT1304T keypad
O que você precisa
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
Conclusão
