Ir para o conteúdo principal
Toshiba A1304T Camera Replacement
O que você precisa
  1. Toshiba A1304T Camera Replacement, Back panel: passo 1, imagem 1 %32
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Camera Replacement: passo 2, imagem 1 %32
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Camera Replacement: passo 3, imagem 1 %32 Toshiba A1304T Camera Replacement: passo 3, imagem 2 %32
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Camera Replacement, Camera: passo 4, imagem 1 %32 Toshiba A1304T Camera Replacement, Camera: passo 4, imagem 2 %32
    • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
    • Gently pull the silver plate from the phone using your fingers.
  5. Toshiba A1304T Camera Replacement: passo 5, imagem 1 %32 Toshiba A1304T Camera Replacement: passo 5, imagem 2 %32 Toshiba A1304T Camera Replacement: passo 5, imagem 3 %32
    • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
    • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
Conclusão
Christopher
Membro desde: 04/22/10
90 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 16-6, Maness Spring 2010 Membro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 99
Ao todo: 2,388
