Ir para o conteúdo principal
Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement
O que você precisa
  1. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: passo 1, imagem 1 %32 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: passo 1, imagem 2 %32
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: passo 2, imagem 1 %32
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing Screws: passo 3, imagem 1 %32
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing the Wheel: passo 4, imagem 1 %32
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Rear Wheel Suspension: passo 5, imagem 1 %32
    • After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
  6. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: passo 6, imagem 1 %32
    • Slide off the bottom part of the rod connected to the chassis.
  7. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: passo 7, imagem 1 %32 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: passo 7, imagem 2 %32 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: passo 7, imagem 3 %32
    • Pull the black washer inside the spring downwards and towards the truck's rear simultaneously in order to remove the suspension.
Conclusão
Uma outra pessoa concluiu este guia.
Colton Sholtis
Membro desde: 01/30/15
257 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-30, Amido Winter 2015 Membro de Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 178
