Ir para o conteúdo principal
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
O que você precisa
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: passo 1, imagem 1 %32 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: passo 1, imagem 2 %32
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 2, imagem 1 %32
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: passo 3, imagem 1 %32
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: passo 4, imagem 1 %32
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: passo 5, imagem 1 %32 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: passo 5, imagem 2 %32
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 6, imagem 1 %32
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 7, imagem 1 %32 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: passo 7, imagem 2 %32
    • Pull up the bottom half of the suspension to unclip it.
Conclusão
Maximiliano Cortes
Membro desde: 02/01/15
418 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-30, Amido Winter 2015 Membro de Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
Membros da 4
Autoria de 16 guias
Um comentário
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 251
