Introdução
This guide shows how to remove and replace the traction cable on the Toro Walk Behind Mower 21199HD 2018.
O que você precisa
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Cut and remove the zip tie holding the cables together near the middle of the handle.
Tilt the mower onto its side, propping the handle up with a block of wood.
Locate the end of the traction cable underneath the mower, attached to the transmission.
Use a pair of needle nose pliers to unhook the traction cable spring from the transmission.
Use a pair of needle nose pliers to depress the two wing clips on the plastic lock.
Once the wing clips are depressed, pull the plastic lock away from the transmission.
Pull the traction cable out through the cutout in the frame.
