Ir para o conteúdo principal
Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement
O que você precisa
  1. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Disconnect the spark plug wire: passo 1, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Disconnect the spark plug wire: passo 1, imagem 2 %32
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Chock the rear wheels: passo 2, imagem 1 %32
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Lift up the deflector: passo 3, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Lift up the deflector: passo 3, imagem 2 %32
    • Lift up the plastic deflector.
  4. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the grass bag: passo 4, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the grass bag: passo 4, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the grass bag: passo 4, imagem 3 %32
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt guard bolts: passo 5, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt guard bolts: passo 5, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt guard bolts: passo 5, imagem 3 %32
    • Use a 3/8-inch socket to remove the four bolts securing the belt guard:
    • Three 1 inch-long recessed bolts
    • One 1 1/2 inch-long bolt
  6. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt guard: passo 6, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt guard: passo 6, imagem 2 %32
    • Pull the belt guard straight off the front of the mower to remove it.
  7. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Loosen the belt tensioner: passo 7, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Loosen the belt tensioner: passo 7, imagem 2 %32
    • Loosen, but don't remove, the belt tensioner to give the belt some slack.
    • Use a 1/2 inch socket and 1/2 wrench simultaneously to loosen the tensioner.
  8. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the pulley plug cap: passo 8, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the pulley plug cap: passo 8, imagem 2 %32
    • Use a flathead screwdriver to pry off the plastic plug cap.
    • Remove the plug cap.
  9. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the upper belt guide: passo 9, imagem 1 %32
    • Use a 3/8 inch socket to remove the four bolts securing the upper belt guide to the pulley.
  10. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 10, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 10, imagem 2 %32
    • Remove the upper belt guide from the pulley.
  11. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the left pulley: passo 11, imagem 1 %32
    • Use a 1/2 inch socket to remove the left pulley bolt
  12. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 12, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 12, imagem 2 %32
    • Remove the pulley bolt and washer.
  13. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 13, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 13, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement: passo 13, imagem 3 %32
    • Remove the left pulley.
    • Remove the bushing from the pulley.
  14. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt from the left sprocket: passo 14, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt from the left sprocket: passo 14, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the belt from the left sprocket: passo 14, imagem 3 %32
    • Lift the belt up and over the left sprocket.
    • Move the belt to the front of the mower, out of the way of the belt tensioner.
    • During reassembly, ensure all belt teeth are fully seated, otherwise there will not be enough slack for the belt to be installed.
    • During reassembly, ensure that the blades are oriented perpendicularly to one another so they don't collide.
    • Spin the left sprocket, with the blade attached underneath, until it is in a safe position, then place the belt on the sprocket.
    • Spin both blades to ensure they don't touch during a 360˚ rotation.
  15. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the sprocket bolt: passo 15, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the sprocket bolt: passo 15, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the sprocket bolt: passo 15, imagem 3 %32
    • Use an impact wrench with a 3/4 inch socket to remove the left sprocket bolt.
    • If necessary, use a punch or screwdriver to lock the sprocket in place during removal, lining up the hole in the sprocket with the hole in the blade guard.
  16. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the sprocket: passo 16, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the sprocket: passo 16, imagem 2 %32
    • While holding the spindle shaft from underneath, lift the sprocket up to remove it.
  17. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the left spindle shaft: passo 17, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the left spindle shaft: passo 17, imagem 2 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the left spindle shaft: passo 17, imagem 3 %32
    • Grabbing the spindle shaft from the bottom, lower it down through the spindle.
    • Remove the spindle shaft from underneath the mower.
  18. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the spindle bolts: passo 18, imagem 1 %32
    • Tilt the mower onto its side so the spindle assembly is facing out.
    • This may require two people.
    • Use a 1/2 inch socket to remove the four spindle bolts.
  19. Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the spindle: passo 19, imagem 1 %32 Toro Walk Behind Mowers 21199HD 2018 Left Spindle Replacement, Remove the spindle: passo 19, imagem 2 %32
    • Remove the spindle.
Conclusão
Carsten Frauenheim
Membro desde: 03/10/20
158.974 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 14
Ao todo: 689
