Ir para o conteúdo principal
Toro Lawn Mower Cutting Blade Replacement
Visualizações: 9,6 mil
Visualizar Estatísticas:
Últimas 24 horas:
7
Últimos 7 dias:
50
Últimos 30 dias:
249
Ao todo:
9.564
Comentários: 2
2 comments on steps.
Concluído: 4
4 pessoas marcaram este guia como "concluído". Será você o próximo?
Favorites: 0
Ninguém favoritou (e se inscreveu) neste guia como favorito. Você será o primeiro?
Tempo necessário: 10 minutos
Dificuldade: Moderado
Introdução
Ir para o passo 1 ↓
Replacing the cutting blade on a lawn mower is important to ensure that your grass is cut correctly and that your lawn mower is running efficiently. This is a simple fix that requires little to no expertise or previous experience. Just make sure to be careful when handling the blade itself and all should run smoothly.
O que você precisa
    1. Toro Lawn Mower Cutting Blade Replacement, Cutting Blade: passo 1, imagem 1 %32
      • Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
      Pergunte ao FixBot
      Comentar
    2. Toro Lawn Mower Cutting Blade Replacement: passo 2, imagem 1 %32
      • Flip the mower onto its side exposing the blade and under carriage.
      Pergunte ao FixBot
      Comentar
    3. Toro Lawn Mower Cutting Blade Replacement: passo 3, imagem 1 %32
      • Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
      Pergunte ao FixBot
      Comentar
    4. Toro Lawn Mower Cutting Blade Replacement: passo 4, imagem 1 %32
      • Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
      • Make sure that safety gloves are worn at all times when handling the new or old cutting blade.
      Pergunte ao FixBot
      Comentar
    5. Toro Lawn Mower Cutting Blade Replacement: passo 5, imagem 1 %32
      • Place the new blade in right side up into the bracket and line up the bolt.
      • Make sure that safety gloves are being worn at all times when handling either the new or old cutting blade.
      Pergunte ao FixBot
      Comentar
    6. Toro Lawn Mower Cutting Blade Replacement: passo 6, imagem 1 %32
      • Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
      Pergunte ao FixBot
      Comentar
    7. Toro Lawn Mower Cutting Blade Replacement: passo 7, imagem 1 %32
      • Flip the mower right-side up and reconnect the spark plug.
      Pergunte ao FixBot
      Comentar
Conclusão
This simple fix should help make the lawn mower function efficiently and safely for years to come.
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 50
Últimos 30 dias: 249
Ao todo: 9,564
