Ir para o conteúdo principal
Torn-Off Backpack Shoulder Strap Repair
O que você precisa
  1. Torn-Off Backpack Shoulder Strap Repair, Torn-Off Backpack Shoulder Strap Repair: passo 1, imagem 1 %32
    • Thread the needle with the 0.7 yards of upholstery nylon thread.
  2. Torn-Off Backpack Shoulder Strap Repair: passo 2, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 2, imagem 2 %32 Torn-Off Backpack Shoulder Strap Repair: passo 2, imagem 3 %32
    • Align the two ends of the thread, and tie a knot.
    • Trim the extra thread off.
  3. Torn-Off Backpack Shoulder Strap Repair: passo 3, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 3, imagem 2 %32
    • Trim the frayed edges and thread off of the backpack and shoulder strap.
  4. Torn-Off Backpack Shoulder Strap Repair: passo 4, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 4, imagem 2 %32
    • Align the 2x5 nylon cloth with the torn off backpack strap.
    • Make sure that the nylon cloth is able to fold over the strap, and align up with the other end.
  5. Torn-Off Backpack Shoulder Strap Repair: passo 5, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 5, imagem 2 %32
    • Begin sewing across the handle with the backstitching sewing technique.
    • Make sure that the stitch goes all the way through the Nylon as you sew.
    • The second picture of this step did not satisfy the second part of this step.
  6. Torn-Off Backpack Shoulder Strap Repair: passo 6, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 6, imagem 2 %32 Torn-Off Backpack Shoulder Strap Repair: passo 6, imagem 3 %32
    • To end the stitch, push the needle about halfway through.
    • Take the thread, and wrap it around the sharp side of the needle.
    • Pull the needle all the way through.
    • If the stitch did not go through both sides of the nylon, repeat steps 5 and 6 over on the other side. Remember to replace the thread by repeating steps 1 and 2.
    • If you want extra support, repeat steps 5 and 6 on the other side. Remember to replace the thread by repeating steps 1 and 2.
  7. Torn-Off Backpack Shoulder Strap Repair: passo 7, imagem 1 %32
    • Cut the thread, and remove the thread from the needle.
    • Repeat steps 1 and 2 with the 1 meter long thread.
  8. Torn-Off Backpack Shoulder Strap Repair: passo 8, imagem 1 %32 Torn-Off Backpack Shoulder Strap Repair: passo 8, imagem 2 %32 Torn-Off Backpack Shoulder Strap Repair: passo 8, imagem 3 %32
    • Align the handle with the shoulder of the backpack.
    • Secure the handle in place by applying pressure, and then begin sewing with the backstitching sewing technique.
    • When sewing, make sure to follow your thread and needle carefully. A misguided needle will lead to unwanted tangles.
    • End the stitch by repeating step 6.
  9. Torn-Off Backpack Shoulder Strap Repair: passo 9, imagem 1 %32
    • Trim off any frayed edges or loose string.
Conclusão
After preceding through all the steps, you should now have a durable, functional backpack! If parts of the strap begin ripping, you can repair the tear by applying the backstitching sewing technique anywhere!
14 outras pessoas executaram este guia.
Emily
Membro desde: 04/07/15
607 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 28-1, Green Spring 2015 Membro de Cal Poly, Team 28-1, Green Spring 2015
CPSU-GREEN-S15S28G1
Membros da 4
Autoria de 8 guias
2 comentários
Emily your tutorial is great the photos are great
thank you. . . !
I know how much work goes into making a tutorial like this
nazo - Responder
Outstanding instructional! Thank you tho for hands down the best tutorial ive come across all day! TY for not starting off with 2 pages of your life story in the beginning too for real. great job with the instructions- easy to follow and to the point. I loved that there were a few pics in each step that if you glided over one of the images, it would highlight and enlarge as the main photo/step. extremely helpful and easy to guide through:) Also, can i just cut a small slice the size of strap through the bag at top and stick the strap end in and hand sew ? or do i have to have another piece of fabric sewn onto the strap to be able to do that....? i am trying to make it look like the strap never broke/was not repaired ya know? Than'Q!
Brit Leaf - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 38
Últimos 7 dias: 276
Últimos 30 dias: 1,273
Duração total: 158,479
