Ir para o conteúdo principal
Top Cover
O que você precisa
  1. Top Cover, Remove screws: passo 1, imagem 1 %32
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
    Pergunte ao FixBot
    Comentar
  2. Top Cover, Disconnect top cover ribbon cable: passo 2, imagem 1 %32
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
    Pergunte ao FixBot
    Comentar
  3. Top Cover, Remove RF shield: passo 3, imagem 1 %32 Top Cover, Remove RF shield: passo 3, imagem 2 %32
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
    Pergunte ao FixBot
    Comentar
Conclusão
Matt Falcon
Membro desde: 05/09/15
2.773 Reputação
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 42
Ao todo: 249
