Ir para o conteúdo principal
Top Cover Removal
O que você precisa
  1. Top Cover Removal, Remove film door: passo 1, imagem 1 %32
    • Push down the latch to release the film door.
  2. Top Cover Removal, Remove top cover screws: passo 2, imagem 1 %32 Top Cover Removal, Remove top cover screws: passo 2, imagem 2 %32 Top Cover Removal, Remove top cover screws: passo 2, imagem 3 %32
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
  3. Top Cover Removal, Remove top cover screws: passo 3, imagem 1 %32 Top Cover Removal, Remove top cover screws: passo 3, imagem 2 %32 Top Cover Removal, Remove top cover screws: passo 3, imagem 3 %32
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
  4. Top Cover Removal, Lift top cover: passo 4, imagem 1 %32
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
  5. Top Cover Removal, Access flash connections: passo 5, imagem 1 %32 Top Cover Removal, Access flash connections: passo 5, imagem 2 %32
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
  6. Top Cover Removal, Discharge flash capacitors: passo 6, imagem 1 %32
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  7. Top Cover Removal, Disconnect right flex cable: passo 7, imagem 1 %32
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
  8. Top Cover Removal, Disconnect left flex cable: passo 8, imagem 1 %32
    • Desolder the red wire.
  9. Top Cover Removal, Desolder flash connections: passo 9, imagem 1 %32 Top Cover Removal, Desolder flash connections: passo 9, imagem 2 %32
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
  10. Top Cover Removal, Desolder the flash flex cable: passo 10, imagem 1 %32 Top Cover Removal, Desolder the flash flex cable: passo 10, imagem 2 %32
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
Conclusão
Sam Gustafson
Membro desde: 09/01/22
2.774 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 74
