Ir para o conteúdo principal
Tonneau Trifold Bed Cover Retention Pin Replacement
O que você precisa
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, imagem 1 %32 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, imagem 2 %32 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: passo 1, imagem 3 %32
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 2, imagem 1 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 2, imagem 2 %32
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, imagem 1 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, imagem 2 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 3, imagem 3 %32
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, imagem 1 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, imagem 2 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 4, imagem 3 %32
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: passo 5, imagem 1 %32 Tonneau Trifold Bed Cover Retention Pin Replacement: passo 5, imagem 2 %32
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
Conclusão
To reassemble your device, follow these instructions in order.
Christopher King
Membro desde: 01/16/18
139 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 747
