Ir para o conteúdo principal
Tommy Hilfiger Quartz Watch Band Link Replacement
O que você precisa
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: passo 1, imagem 1 %32
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 2, imagem 1 %32
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, imagem 2 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, imagem 3 %32
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, imagem 2 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, imagem 3 %32
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 5, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 5, imagem 2 %32
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, imagem 2 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, imagem 3 %32
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 7, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 7, imagem 2 %32
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, imagem 1 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, imagem 2 %32 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, imagem 3 %32
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 9, imagem 1 %32
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Linha de Chegada
Ayush Theyyil
Membro desde: 09/14/21
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 101
Duração total: 6,174
