Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Peel back the sticker on the bottom of the device to reveal the two screws.
Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
Identify the green motherboard. Unscrew the three screws holding the board in place.
Plug the new battery into the white receptacle on the green motherboard.
Transfer the green motherboard back into the back plate and secure it with the 3 screws.
Reconnect the yellow ribbon cable and connect the screen and back plate back together.
5 outras pessoas executaram este guia.
Um comentário
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
