Ir para o conteúdo principal
TomTom XXL 540 Battery Replacement
O que você precisa
  1. TomTom XXL 540 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540 Battery Replacement: passo 2, imagem 1 %32
    • Unscrew the two T5 Torx screws.
  3. TomTom XXL 540 Battery Replacement: passo 3, imagem 1 %32
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. TomTom XXL 540 Battery Replacement: passo 4, imagem 1 %32
    • Release the yellow ribbon cable.
  5. TomTom XXL 540 Battery Replacement: passo 5, imagem 1 %32
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  6. TomTom XXL 540 Battery Replacement: passo 6, imagem 1 %32
    • Remove the motherboard from the back plate.
  7. TomTom XXL 540 Battery Replacement: passo 7, imagem 1 %32
    • Unplug the battery from the board.
  8. TomTom XXL 540 Battery Replacement: passo 8, imagem 1 %32
    • Plug the new battery into the white receptacle on the green motherboard.
  9. TomTom XXL 540 Battery Replacement: passo 9, imagem 1 %32
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  10. TomTom XXL 540 Battery Replacement: passo 10, imagem 1 %32
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  11. TomTom XXL 540 Battery Replacement: passo 11, imagem 1 %32
    • Insert the t-5 screws and tighten to secure.
  12. TomTom XXL 540 Battery Replacement: passo 12, imagem 1 %32
    • Replace the label to cover the screws.
Conclusão
5 outras pessoas executaram este guia.
Mike Sollars
Membro desde: 07/11/13
519 Reputação
Autoria de 3 guias
Equipe
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
Membros da 4
Autoria de 6 guias
Um comentário
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
Jim Shaw - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 4,586
