Ir para o conteúdo principal
TomTom XL Screen and Motherboard Replacement
O que você precisa
  1. TomTom XL Screen and Motherboard Replacement, Screen and Motherboard: passo 1, imagem 1 %32
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Screen and Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Screen and Motherboard Replacement: passo 3, imagem 1 %32 TomTom XL Screen and Motherboard Replacement: passo 3, imagem 2 %32 TomTom XL Screen and Motherboard Replacement: passo 3, imagem 3 %32
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Screen and Motherboard Replacement: passo 4, imagem 1 %32 TomTom XL Screen and Motherboard Replacement: passo 4, imagem 2 %32
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Screen and Motherboard Replacement: passo 5, imagem 1 %32 TomTom XL Screen and Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Screen and Motherboard Replacement: passo 6, imagem 1 %32 TomTom XL Screen and Motherboard Replacement: passo 6, imagem 2 %32
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
Conclusão
Uma outra pessoa concluiu este guia.
Adam Johnson
Membro desde: 04/21/10
122 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 33-84, Johann Spring 2010 Membro de Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 9,029
