Ir para o conteúdo principal
TomTom XL Battery Replacement
O que você precisa
  1. TomTom XL Battery Replacement, Screen and Motherboard: passo 1, imagem 1 %32
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Battery Replacement: passo 2, imagem 1 %32
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Battery Replacement: passo 3, imagem 1 %32 TomTom XL Battery Replacement: passo 3, imagem 2 %32 TomTom XL Battery Replacement: passo 3, imagem 3 %32
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Battery Replacement: passo 4, imagem 1 %32 TomTom XL Battery Replacement: passo 4, imagem 2 %32
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Battery Replacement: passo 5, imagem 1 %32 TomTom XL Battery Replacement: passo 5, imagem 2 %32
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Battery Replacement: passo 6, imagem 1 %32 TomTom XL Battery Replacement: passo 6, imagem 2 %32
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
  7. TomTom XL Battery Replacement, Battery: passo 7, imagem 1 %32
    • Slip a small plastic opening tool under the battery and slowly pry the battery up.
    • The battery is held on with strong adhesive, so it may require some force. Work slowly and carefully to avoid damaging the housing
    • Remove the battery from the housing.
Conclusão
13 outras pessoas executaram este guia.
Sean Higginson
Membro desde: 04/21/10
209 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 33-84, Johann Spring 2010 Membro de Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Membros
Autoria de 5 guias
12Comentários do guia
Note: There are several variants of this. Some of them have 2 screws on the bottom under the stickers. You'll need to remove those first.
nathan - Responder Compartilhar
Awesome and very detailed guide. Thanks for this.
Phil Harris - Responder Compartilhar
Great demo, for replacement tomtom batteries take a look at : TomTom batteries
based in the UK they are reliable and give a truly longer charge
Kermit45 - Responder Compartilhar
This was a great help. Followed the instructions and it was that easy. Thanks
mark - Responder Compartilhar
nathanrenniewaldock is right... I cracked my screen before finding the hidden screws on the bottom. what a silly company to use the same name for different models!
Laz - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 60
Ao todo: 52,241
