Ir para o conteúdo principal
TomTom VIA 1530 TM Motherboard Replacement
O que você precisa
  1. TomTom VIA 1530 TM Motherboard Replacement, Back: passo 1, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement, Back: passo 1, imagem 2 %32
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
  2. TomTom VIA 1530 TM Motherboard Replacement: passo 2, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement: passo 2, imagem 2 %32
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  3. TomTom VIA 1530 TM Motherboard Replacement: passo 3, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement: passo 3, imagem 2 %32
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
  4. TomTom VIA 1530 TM Motherboard Replacement: passo 4, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
  5. TomTom VIA 1530 TM Motherboard Replacement: passo 5, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement: passo 5, imagem 2 %32 TomTom VIA 1530 TM Motherboard Replacement: passo 5, imagem 3 %32
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
  6. TomTom VIA 1530 TM Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 TomTom VIA 1530 TM Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
    • Slide the gold ribbon cable out of the port.
Conclusão
Uma outra pessoa concluiu este guia.
Jennifer Zakaria
Membro desde: 01/18/18
555 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S12-G2, Banghart Winter 2018 Membro de Cal Poly, Team S12-G2, Banghart Winter 2018
CPSU-BANGHART-W18S12G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 317
