Ir para o conteúdo principal
TomTom One XL Charging Port Replacement
O que você precisa
  1. TomTom One XL Charging Port Replacement, Back Panel: passo 1, imagem 1 %32 TomTom One XL Charging Port Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Charging Port Replacement: passo 2, imagem 1 %32
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Charging Port Replacement: passo 3, imagem 1 %32
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Charging Port Replacement: passo 4, imagem 1 %32 TomTom One XL Charging Port Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Charging Port Replacement, Charging Port: passo 5, imagem 1 %32 TomTom One XL Charging Port Replacement, Charging Port: passo 5, imagem 2 %32
    • If this is your first time solder then refer to IFixIt's safety guide.
    • Locate where the charger port goes on the circuit board.
    • Locate the four connecter on circuit board and charger port which need to be soldered.
    • Don't forget, the soldering iron is hot.
  6. TomTom One XL Charging Port Replacement: passo 6, imagem 1 %32 TomTom One XL Charging Port Replacement: passo 6, imagem 2 %32 TomTom One XL Charging Port Replacement: passo 6, imagem 3 %32
    • Using your plastic opening tool press down firmly on the top of the charger port.
    • While the soldering iron is hot press it again the four corners of the charger port.
    • Don't touch the charger port with your hands, it may have heated up during soldering.
  7. TomTom One XL Charging Port Replacement: passo 7, imagem 1 %32 TomTom One XL Charging Port Replacement: passo 7, imagem 2 %32 TomTom One XL Charging Port Replacement: passo 7, imagem 3 %32
    • Let the circuit board and charger port cool down for a few minutes.
    • Lift circuit board up, after making sure its cool, to see if four corners are all connected.
    • Plug in the charger to make sure it works, if not repeat steps and make sure the port is making a clean connection.
Conclusão
DeVhan
Membro desde: 03/11/15
401 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 2,411
