Ir para o conteúdo principal
TomTom One XL Battery Replacement
O que você precisa
  1. TomTom One XL Battery Replacement, Back Panel: passo 1, imagem 1 %32 TomTom One XL Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: passo 2, imagem 1 %32
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: passo 3, imagem 1 %32
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: passo 4, imagem 1 %32 TomTom One XL Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: passo 5, imagem 1 %32
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: passo 6, imagem 1 %32 TomTom One XL Battery Replacement: passo 6, imagem 2 %32 TomTom One XL Battery Replacement: passo 6, imagem 3 %32
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: passo 7, imagem 1 %32 TomTom One XL Battery Replacement: passo 7, imagem 2 %32 TomTom One XL Battery Replacement: passo 7, imagem 3 %32
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: passo 8, imagem 1 %32 TomTom One XL Battery Replacement: passo 8, imagem 2 %32 TomTom One XL Battery Replacement: passo 8, imagem 3 %32
    • Reconnect the battery ribbon cable to its port.
Conclusão
DeVhan
Membro desde: 03/11/15
401 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,463
