Introdução
Batteries do not last forever, so this guide is to show you how to replace the battery.
O que você precisa
Ferramenta utilizada nesse passo:Tweezers$4.99
Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
3 outras pessoas executaram este guia.
