Introdução
Please check out the TomTom GO Live 1535M Troubleshooting Guide before taking the device apart to ensure you are following the correct repair procedure.
O que você precisa
Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
Carefully remove the reset button cable (located on the left) and the ribbon cable.
The screen is simply removed by pushing it up-and-out of the outside rim (denoted by the box).
If you need to find a replacement screen, please click the link here. Link text
Um comentário
I just replaced the screen. But with the cable ribbon installed the screen does not activate. The startup tom-tom sound does play. The screen is blank. But the old screen does not work as well. Prior to this the screen did work but was un responsive. Any thoughts?
