Ir para o conteúdo principal
TomTom GO Live 1535M Reset Button Activation
O que você precisa
  1. TomTom GO Live 1535M Reset Button Activation, Reset Button: passo 1, imagem 1 %32
    • The reset button is located at the top of the device, close to the charging port. It is a small hole that is .78 mm wide.
    • Insert one end of the paper clip into the small power button hole and press down gently until you hear a "click" sound.
    • Hold paper clip in power button hole for 15 seconds.
    • The device should power on by itself with its factory default settings in place once done. If you do not see the screen power on, go back to step 1 and try repowering again.
Conclusão
Mathias Sagide
Membro desde: 01/20/15
618 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 19-4, Blackwell Spring 2014 Membro de USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Membro
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 3,225
