Introdução
If your TomTom Go Live does not seem to be charging or hold said charge, then the battery needs to be replaced. This guide will show how to take this device apart and replace the battery without damaging the screen or cables.
O que você precisa
Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
Simply lift the battery up and out of the base.
Remove the cable.
Replace the battery.
4 outras pessoas executaram este guia.
