Ir para o conteúdo principal
TomTom GO 500 Speaker Replacement
O que você precisa
  1. TomTom GO 500 Speaker Replacement, TomTom GO 500 Opening the Device: passo 1, imagem 1 %32
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Speaker Replacement: passo 2, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Speaker Replacement: passo 3, imagem 1 %32
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Speaker Replacement: passo 4, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 4, imagem 2 %32 TomTom GO 500 Speaker Replacement: passo 4, imagem 3 %32
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Speaker Replacement: passo 5, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 5, imagem 2 %32
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Speaker Replacement, Motherboard: passo 6, imagem 1 %32
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. TomTom GO 500 Speaker Replacement: passo 7, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. TomTom GO 500 Speaker Replacement: passo 8, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 8, imagem 2 %32
    • Unplug the second connector using the plastic opening tool.
  9. TomTom GO 500 Speaker Replacement: passo 9, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 9, imagem 2 %32
    • Remove the motherboard from the casing.
  10. TomTom GO 500 Speaker Replacement, Speaker: passo 10, imagem 1 %32
    • The speaker is located next to the battery.
  11. TomTom GO 500 Speaker Replacement: passo 11, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 11, imagem 2 %32 TomTom GO 500 Speaker Replacement: passo 11, imagem 3 %32
    • Pinch the speaker at the rubber grommets and tug gently.
  12. TomTom GO 500 Speaker Replacement: passo 12, imagem 1 %32 TomTom GO 500 Speaker Replacement: passo 12, imagem 2 %32 TomTom GO 500 Speaker Replacement: passo 12, imagem 3 %32
    • Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker.
Conclusão
Nicholas Maharaj
Membro desde: 09/22/16
101 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-5, Oliver Fall 2016 Membro de UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 455
