Introdução
The motherboard contains all of the device's ports while the speaker, battery, and microphone are separate from the motherboard. Confirm the device is powered off before starting the disassembly.
O que você precisa
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
4 outras pessoas executaram este guia.
