Ir para o conteúdo principal
TomTom GO 500 Display or Digitizer Replacement
O que você precisa
  1. TomTom GO 500 Display or Digitizer Replacement, TomTom GO 500 Opening the Device: passo 1, imagem 1 %32
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Display or Digitizer Replacement: passo 2, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Display or Digitizer Replacement: passo 3, imagem 1 %32
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Display or Digitizer Replacement: passo 4, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 4, imagem 2 %32 TomTom GO 500 Display or Digitizer Replacement: passo 4, imagem 3 %32
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Display or Digitizer Replacement: passo 5, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 5, imagem 2 %32
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: passo 6, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the microphone on the left side of the screen casing using tweezers.
    • Use tweezers with rounded tips to avoid damaging the microphone.
  7. TomTom GO 500 Display or Digitizer Replacement: passo 7, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 7, imagem 2 %32
    • Lift up the small black tab on the orange connector using a plastic opening tool. This releases the strip connecting the display to the digitizer.
  8. TomTom GO 500 Display or Digitizer Replacement: passo 8, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 8, imagem 2 %32
    • Slide the connector strip out from the tab.
  9. TomTom GO 500 Display or Digitizer Replacement: passo 9, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 9, imagem 2 %32
    • Unscrew the eight 2.5mm screws along the perimeter of the display using the Phillips #000 screwdriver.
  10. TomTom GO 500 Display or Digitizer Replacement: passo 10, imagem 1 %32 TomTom GO 500 Display or Digitizer Replacement: passo 10, imagem 2 %32 TomTom GO 500 Display or Digitizer Replacement: passo 10, imagem 3 %32
    • Separate the display from the digitizer. The display is now fully removed from the device.
Conclusão
6 outras pessoas executaram este guia.
Jennie Chang
Membro desde: 09/22/16
173 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-5, Oliver Fall 2016 Membro de UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Membros
Autoria de 9 guias
3Comentários do guia
If you keep the bezel and replace the glass, ensure the glass has adhesive before you buy.
Aaron - Responder Compartilhar
Do you have branch in Istanbul?
if yes please provide me the address. thaxs
Bsssam Kabeir - Responder Compartilhar
pertituire schermo e display cosa devo fare e comprare grazie
Cesare - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 76
Ao todo: 7,268
