Introdução
Is your device making excessive noise? The following are the steps to take to replace the two small washers connected to the lever arm. Broken or malfunctioning washers can cause noises and a less smooth massage. Thus, if the massage gun makes noises it is not supposed to make, a replacement of said washers might be a solution.
O que você precisa
Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
