Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lift the tank lid up and away from the toilet tank.
Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
Push down the flush lever.
Hold the lever down until water stops draining from the tank.
Use a sponge to soak up and remove any remaining water from the toilet tank.
Periodically squeeze the excess water from the sponge.
Place a bucket under the supply tube to catch any dripping water.
Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
Lift the tank up from the lower half of the toilet.
11 outras pessoas executaram este guia.
3 comentários
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
Thank you for the info.
