Ir para o conteúdo principal
Toilet Seat Replacement
O que você precisa
  1. Toilet Seat Replacement, Toilet Seat: passo 1, imagem 1 %32
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: passo 2, imagem 1 %32 Toilet Seat Replacement: passo 2, imagem 2 %32
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: passo 3, imagem 1 %32 Toilet Seat Replacement: passo 3, imagem 2 %32 Toilet Seat Replacement: passo 3, imagem 3 %32
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: passo 4, imagem 1 %32 Toilet Seat Replacement: passo 4, imagem 2 %32
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: passo 5, imagem 1 %32
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: passo 6, imagem 1 %32
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
Conclusão
To re-install your previous seat, follow these instructions in reverse order.
Christopher Carter
Membro desde: 02/24/15
231 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-5, Green Winter 2015 Membro de Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 80
Ao todo: 2,567
